Join TechIMO for Free!
Thread Tools
Currently Active Users: 2905
Discussions: 188,281, Posts: 2,242,413, Members: 232,448
Old October 8th, 2008, 07:24 PM   Digg it!   #1 (permalink)
My New Project (Long Term)
Not even 2 weeks after making the purchase of the parts of the computer I've decided to dub "Seika" (Sacred Flame- Due to the fact It's using Crossfire Tech), I am now going to start to make one for SLI. However this one will be water cooled. Now it's already a given that I will be using Vista 64bit. Now I don't know what's the best case for water cooling or the best water cooler. This time though since this a long term project (2-4 Months) the budget will be a bit higher: $1700-$2000. This will include monitor, Case, PSU, Motherboard, Ram, Keyboard and Mouse, GPU and Sound Card. Again I have Hard drives and DVD drives up the wazoo so no need for them.
I'll be posting my build soon, so in the meantime I'd like to hear about water cooling and such. This is a nVidia based system so I'll try to reflect that in the parts I choose.
SirRob is offline   Reply With Quote
Old October 8th, 2008, 07:28 PM     #2 (permalink)
Performance Whore
KarmaKiller's Avatar
What do you want to know about water cooling? I can help ya with that.
Fold for Team TechIMO and Win free stuff! <-link->
|Folding@Home FAQ's| Team Stats|
KarmaKiller is online now   Reply With Quote
Old October 8th, 2008, 07:37 PM     #3 (permalink)
Well I live on a mountain (as you may know) and for me the cold is no problem, since winter is coming and I keep the windows open (and the computers are near windows) It'll be around 0c-10c normally. For the water cooling what type of liquid won't freeze if it isn't moving. Meaning when I power down and leave it for the night will the cooling liquid freeze? I mean I'm half tempted to use vodka and dispose of it the old fashion way when replacing it (that and vodka doesn't freeze...I'll let you be the judge the real reason I want it). So aside from that what tubing and case go best for it?
Old October 8th, 2008, 08:00 PM     #4 (permalink)
Performance Whore
Don't use vodka.. That's not a good idea..
There are a ton of different liquids you can use. Most people use a mix though, as the pre-mixed solutions are like $30 a bottle. IMO, that's a little much. Distilled water is best, no mineral build ups that way. You can mix that with some anti-freeze, pre-mixed solution, there are all kinds of different ways you can go. Right now I'm using distilled water and anti-freeze, with dye. I had some PC-tonic (pre-mixed) but I ran out.
You have to watch out for build ups. And when you mix metals in your loop (brass, copper,etc) you really have to watch out more for it. But basically, you can use straight distilled water, with a little bit of some kind of biocide/anti-freeze stuff.
As far as tubing, that's really up to you. There are some "name brands" that don't kink as easy, or have some kind of color. But I just picked up 15' of clear tubing from lowe's, and got some anti-kink coils. It adds the look I wanted, and prevents kinks.
You can spring for the name brand stuff, but it's more expensive, and really besides the kinks thing, offers nothing different.
Here's a couple of the best stores for H20 gear:
Jab-tech
Petra's Tech Shop
Danger*Den
Performance-PCs.com, ... sleeve it and they will come
Sidewinder Computers - Supplier of High Quality PC Modding and Cooling parts
FrozenCPU.com | 1.877.243.8266 | World's Largest Selection of PC Modification Supplies
PC Mods, Case Mods, PC Cooling, Gaming, and More - Crazy PC
Here's a link to pics of my system, so you can see what I'm talking about with the anti-kink coils.
http://i99.photobucket.com/albums/l3...d/P1020010.jpg
http://i99.photobucket.com/albums/l3...d/P1010994.jpg
Old October 8th, 2008, 08:19 PM     #5 (permalink)
Water doesnt freeze till 0 + the heat of your System No way it will freeze . I would use a bit of anti freeze to kill Algee and then you know for sure it wont freeze .
E8400 8.5x500=4250mhz 1.38v 24/7 ( 4.7-4.9ghz for benchs ) /Evga 780i
OCZ PC-6400 5-4-4-15 800mhz 1.9v / Corsair 620hx / 8800gt @ 740/1800/1000 24/7
||Console|| is offline   Reply With Quote
Old October 8th, 2008, 08:21 PM     #6 (permalink)
Well I'm going for clear tubing and a special dye since at night my room is lighted by UV lights. 3 of them to be exact. So I think that would look nicer.
As for pumps though, I have no idea about whats good or not.
Old October 8th, 2008, 08:42 PM     #7 (permalink)
Performance Whore
Swiftech and Laing are the most popular. And actually they are the same thing, Swiftech just rebadges them in their name.
D-tek's are also good for the price. Some of their pumps are a little weaker though, so you might have to have 2, or just multiple loops.
If your wanting to go cheap you could pick up a Via pump for about $30 from a pet store. They also work well.
As far as tubing, you can go cheap by getting it at lowes for $2.50 for 15', or you can buy some Tygon stuff for around $2.50 a foot. Or you can pick up some Feser stuff for $2.75- $3 a ft from online dealers.
Old October 8th, 2008, 08:49 PM     #8 (permalink)
Well my main concern is the best possible cooling for my buck. Since it's a $1700-$2k system I want to make sure no leaks and great cooling.
Old October 8th, 2008, 10:59 PM     #9 (permalink)
Performance Whore
I understand.
So my next question would be, what components do you plan on putting on the water loop?
I'm guessing GPU/CPU. Do you plan on adding RAM/Mosfet/NB/SB cooling?
That determines how many loops, how big/many rads you need, etc..
Old October 8th, 2008, 11:12 PM     #10 (permalink)
Yes, CPU and GPU would be the major components. Ram won't be a problem nor the NB/SB.
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Recomendations for long term storage of a Inkjet printer videobruce Graphic Design and Digital Photography 3 March 5th, 2008 09:51 AM
Sega Doubts Wii's long-term potential SoloCamo General Gaming Discussion 14 June 26th, 2007 10:15 AM
Comp freezes during long term processes RogueLemming General Tech Discussion 6 July 1st, 2004 03:57 PM
Are there cases for long-term HD storage? MikeGn General Tech Discussion 43 January 29th, 2004 07:39 PM
US to Discontinue Long-Term, Low-Yield Investment in Nation's Youth Theophylact IMO Community 1 September 26th, 2003 10:37 PM
Is It Just Me? (2745)
Titan quest and Immortal Throne, an.. (12)
Happy Birthday NeoStarO1 (9)
Howdo I determine if usb port is 2... (5)
Vista printing Problems? (5)
FolderChat: Weekend time again! (375)
wireless security key (5)
Going to upgrade, is it better to g.. (5)
New build, need advice please. (15)
Can't get any help from Shareza.. (3)
Titan quest and Immortal Throne.. (12)
Genuine Broadband Connection my.. (7)
XP- same disc, different key (4)
Buy.com Deals - Including Acer .. (1)
Converting a scanner (7)
Need help removing my front usb.. (0)
Linksys WPC54G install problem (0)
Extended monitor color issue (3)
Vista: wireless network not sav.. (15)
P4 system for Sale (5)
Meritline.com USB Vacuum Cleane.. (2)
